Selecting entities
Manipulation commands, such as MOVE, COPY and MIRROR prompt you to select one or more entities. If the PICKFIRST variable is ON, you can also compose the selection set before launching the command.
BricsCAD provides several selection methods. You can combine selection methods to compose a selection set.
Selecting entities one by one
  1. Move the cursor over the entity.
    The entity highlights.
    The Quad appears and displays the most recently used command and a selection of the entity properties.
  2. Do one of the following:
    • Click to select the entity.
    • Repeatedly press the Tab key to highlight obscured entities and click when the desired entity highlights.
  3. Repeat the previous steps to select more entities or launch a command.
Selecting multiple entities
BricsCAD uses window selection methods to select multiple entities:
  1. Click to define the corner of the selection rectangle.
    • Move the cursor to the right. A blue rectangle displays. The circle inside the rectangle icon indicates all entities that lie completely within the selection rectangle will be selected.
    • Move the cursor to the left. A green rectangle displays. The circle overlapping the rectangle icon indicates that all entities which either lie within or overlap the selection rectangle will be selected.
  3. Click to define the opposite corner of the selection rectangle.
