Deactivate or revoke a BricsCAD license
Deactivating a license
Use this procedure to:
  • Migrate a license to another computer.
  • Permanently remove BricsCAD from a computer.
  • Reactivate BricsCAD after installing a new hard disk, changing partitions, or upgrading the operating system.
To deactivate a BricsCAD license, an internet connection is required. You cannot manually deactivate a license via another computer that is connected to the internet.
Note: You cannot deactivate:
  • Single and volume licenses that are manually activated.
  • Network licenses.
  • Trial licenses.
The chart explains how to deactivate a BricsCAD license. If it is not possible to deactivate a BricsCAD license, you can revoke the license.
To deactivate a license:
  1. Launch the LICENSEMANAGER command. Click the Manage License option on the Bricsys License Manager dialog box.
    The License Manager dialog box displays.
  2. If your computer connects to the license server through a proxy server, click Proxy Settings... to configure the proxy settings.
  3. Click Deactivate...
  4. Click the Yes button on the confirmation dialog box to deactivate the license.
    The license is deactivated and can be activated on another computer.
Note: There is no limited number of deactivations. To move a license, always use the deactivate and reactivate options.
Revoking a license
Important:
  • Only revoke a license if deactivation is not possible.
  • The revoke possibility is limited to two per key.
  • Deactivate a network license or a single or volume license manually that is manually activated.
  • Reactivate BricsCAD after a hard disk crash.
To revoke a license:
  1. Log in to the BricsCAD website using the account that is associated with your license.
  2. Click the My Account icon () and select Manage licenses (1) in the menu.
  3. Hover over the license key of the license you want to revoke and click on the pencil icon ().
  4. Scroll down and click the X icon to revoke the license.
Note: If you are a Maintenance user, contact support to review your additional revoke request.
