Modifying a BricsCAD license Use this procedure to upgrade or replace a license. Launch the LICENSEMANAGER command. The Bricsys License Manager dialog displays. Click Manage License. The Licensing Information dialog box displays. Click the Modify button. The BricsCAD License Manager - Activate BricsCAD dialog box displays. Paste your license key in the License Key field. Click the OK button. Your license key is registered over the internet. A dialog displays when the license key is successfully activated. Read the text on the dialog box and click the I understand button. Parent topic: BricsCADParent topic: Activating BricsCADRelated informationLICENSEMANAGER commandRelated informationDeactivating or revoking a BricsCAD licenseOverview of licensing options
