Network license usage report
Possibilities to check the network license usage:
- On the RLM web UI
Browse to http://localhost:5054/ and go to .
- In the bricsys.dlog file (contains the IN/OUT information)
This file is in the RLM folder: C:\Program Files\Bricsys\Bricsys Network License Server.
- Using the REPORTLOG option
This option is described on pages 66 and 90 in the RLM License Administration manual and it should be added to the bricsys.opt as follows:
REPORTLOG +D:\your_path\report_name.logNote:- After adding the option, perform a Reload/Restart Servers.
- The
+sign means the new data is appended to the file, otherwise the file is overwritten.
- Using a third party software
- RLM License Administration Bundle
Browse to https://support.reprisesoftware.com/support/admin/license-administration-bundle/
- JTB FlexReport
Browse to https://jtbworld.com/jtb-flexreport
