Network license usage report
There are several possibilities to check the network license usage:
- From the RLM web UI:Browse to http://localhost:5054/ and go to .
From the bricsys.dlog file which contains the IN/OUT information. This file is in the RLM folder: C:\Program Files\Bricsys\Bricsys Network License Server.
- REPORTLOG option. This option is described on pages 79 and 106 in the RLM License Administration manual.It should be added to the bricsys.opt file like this: REPORTLOG +D:\your_path\report_name.logNext, perform a Reread/Restart Servers. The + sign means the new data is appended to the file, otherwise the file will be overwritten.
RLM License Administration Bundle: https://reprisesoftware.com/admin/software-licensing-downloads.php
JTB FlexReport:
