Network license usage report
There are several possibilities to check the network license usage:
- From the RLM web UI:
Browse to http://localhost:5054/ and go to .
From the bricsys.dlog file which contains the IN/OUT information. This file is in the RLM folder: C:\Program Files\Bricsys\Bricsys Network License Server.
- REPORTLOG option. This option is described on pages 66 and 90 in the RLM License Administration manual.
It should be added to the bricsys.opt file like this:
REPORTLOG +D:\your_path\report_name.logNext, perform a Reread/Restart Servers.
The + sign means the new data is appended to the file, otherwise the file will be overwritten.
RLM License Administration Bundle:
https://support.reprisesoftware.com/support/admin/license-administration-bundle/
JTB FlexReport:
