Network license usage report
There are several possibilities to check the network license usage:
From the RLM web UI
go to localhost:5054/home.asp > Status > License Usage > bricsys
From the "bricsys.dlog" file, which contains the IN/OUT information. This file is located in RLM folder C:\Program Files\Bricsys\Bricsys Network License Manager.
REPORTLOG option. This option is described on pages 80 and 107 in the RLM manual:
http://www.reprisesoftware.com/RLM_License_Administration.pdf
It should be added to the bricsys.opt file like this:
REPORTLOG +D:\your_path\report_name.log
Next, perform a Reread/Restart Servers.
The + sign means the new data is appended to the file, otherwise the file will be overwritten.
RLM License Administration Bundle
https://reprisesoftware.com/admin/software-licensing-downloads.php
JTB FlexReport
