License levels
- BricsCAD® Lite
- BricsCAD® Pro
- BricsCAD® BIM
- BricsCAD® Mechanical
- BricsCAD® Ultimate
BricsCAD® Lite
If you only create general 2D designs, BricsCAD® Lite may be the right choice for you. Compared to AutoCAD LT®, it also allows to view, move, copy, or mirror 3D models. However, it is not possible to edit the model or create new 3D entities. BricsCAD® Lite also runs Lisp routines. Lisp allows BricsCAD® users to load customized routines or small applications that will run in BricsCAD®.
BricsCAD® Pro
BricsCAD® Pro includes direct 3D modeling with a full 3D constraint system, rendering with materials and lighting and access to third party applications.
BricsCAD® BIM
BricsCAD® BIM includes all BricsCAD® Pro features. You can use your current CAD skills to smoothly move to creating real Building Information Models in record time. One product, one workflow, all in industry-standard DWG.
On top of all BricsCAD® Pro features, BricsCAD® Mechanical includes a complete mechanical design toolkit, all in industry-standard DWG, including sheet metal functionality.
BricsCAD® Ultimate
BricsCAD® Ultimate combines the BricsCAD® BIM and BricsCAD® Mechanical features.
