Minimum system requirements and recommendations
System requirements and recommendations for Intel and AMD-based Microsoft Windows & Linux PCs, and Intel-based Apple Macs.
Supported Operating Systems |
Note: Windows 8.1 will reach the end of Microsoft’s Extended Support program
on 10 January 2023.
Note: Mac OSX is supported only on Intel-based hardware at this time.
Deprecated Operating Systems |
Note: we do not recommend running mission-critical CAD software on
unsupported operating systems, as your PC may become more vulnerable to
security risks.
Minimum CPU:
Recommended CPU:
The CPU with the highest single-thread performance rating will always excel with BricsCAD. Additional CPU cores can be a bonus, because BricsCAD supports the concept of ‘helper threads’ for many data- and calculation-intensive tasks. Note about Intel® Xeon® and AMD Ryzen™ Threadripper™ CPUs: these top-tier workstation CPUs support large on-chip memory cache, more PCIe® I/O lanes and multi-channel, high speed memory architectures. Will they help BricsCAD run faster? Maybe. You will need to do testing in your specific environment, to determine if the additional cost of these systems is justifiable. |
Minimum System Memory: 8 GB |
Recommended System Memory:
For maximum performance, determine the memory configuration of your PC and ensure that each memory channel on the motherboard is populated with at least one memory module (SIMMs/DIMMs). Note: the number of available memory channels may not correlate 1:1 with
the number of RAM sockets on your PC’s motherboard. Questions? Please
check with your hardware supplier before you buy system memory.
Minimum Disk Space: 2 GB for BricsCAD Ultimate, installed |
Recommended Disk Space: (As needed) |
We recommend Solid-State Drives (SSDs) as system drives, for both BricsCAD and Windows. Drawings and support files can reside on slower mechanical hard disk drives, if necessary. Note: solid-state disks can be up to 10x faster reading and 20x faster
writing data than a mid-range hard disk drive (for example Seagate
Barracuda 5.4k RPM, SATA 6.0).
Minimum Display System:
Recommended Display System:
On Microsoft Windows systems, most graphics cards & GPUs from NVIDIA, AMD and Intel® are supported. On Linux systems, most graphics cards and GPUs from NVIDIA and AMD are supported. On Mac systems, native Apple display hardware is supported. BricsCAD’s non-wireframe display modes are generated by RedSDK technology from Redway3D®. For maximum RedSDK performance in these modes, a GPU is required. Note: We suggest that you install the latest drivers available for your
display hardware, as recommended by the manufacturer.
Note to Linux users: Hardware acceleration of 3D graphics on Linux systems is NOT supported on:
For more information about supported graphics hardware for BricsCAD, see the Redway3D GPU chipset reference page. |
