Silent installation (Windows only)
Open PowerShell or Command Prompt with administrator rights, change the directory (cd) to the folder containing the BricsCAD MSI installer and run msiexec /i BricsCAD-V27.1.05-1-en_US(x64).msi /qn /norestart to perform a silent installation without user interaction or automatic restart.
More options
ADDDESKTOPSHORTCUT=""suppresses the addition of a desktop shortcut.SHOWRELEASENOTES=""suppresses the display of the Release Notes when the installation completes.APPLICATIONFOLDER="your_app_folder"installs BricsCAD in a custom folder.BRXLICENSEDESTFILE="path_to_lic_file"specifies a folder for the license file if any of the properties BRXLICENSEKEY, BRXLICENSEFILE or BRXLICENSESERVER are defined.The default folder is: C:\ProgramData\Bricsys.
BRXLICENSEKEY="your_license_key"activates the license and stores it in the folder specified by BRXLICENSEDESTFILE.BRXLICENSEFILE="your_license_file"copies the license file to the folder specified by BRXLICENSEDESTFILE.BRXLICENSESERVER="host", orBRXLICENSESERVER="port@host"(*) creates a license file in the folder specified by BRXLICENSEDESTFILE, containing the server host specification.(*) If your license server uses a port other than the default port 5053.
REBOOT=ReallySuppresssuppresses a restart after the installation is complete.- (On 32-BIT only)
INSTALLVBA="0"orINSTALLVBA=""does not install VBA.Note: The 32-BIT version is only available for BricsCAD V20 and older.
Examples of command prompts
- To perform a silent installation while suppressing the creation of a desktop shortcut and the display of Release Notes:
msiexec /i "BricsCAD-Vxx.x.xx-x-en_US(x64).msi" /qn ADDDESKTOPSHORTCUT="" SHOWRELEASENOTES="" - To execute a silent installation and activate the license using the provided license key:
msiexec /i "BricsCAD-Vxx.x.xx-x-en_US(x64).msi" /qn BRXLICENSEDESTFILE= "C:\ProgramData\Bricsys\BricsCAD.lic" BRXLICENSEKEY="****-****-****-****-****"The license file, BricsCAD.lic, is generated at the specified location, C:\ProgramData\Bricsys, ensuring that all BricsCAD versions automatically find it.
- To create the license file containing the server host specification in the assigned folder, C:\ProgramData\Bricsys, ensuring that all BricsCAD versions automatically find it:
msiexec /i "BricsCAD-Vxx.x.xx-x-en_US(x64).msi" /qn BRXLICENSESERVER="port@host" BRXLICENSEDESTFILE="C:\ProgramData\bricsys\BricsCAD.lic"
