Silent Installation (Windows only)
For silent installation, you need admin rights.
Open PowerShell or Command Prompt and change the directory (cd) to the location of the BricsCAD® installer .msi file.
Note: In Windows 10, you can access the Open PowerShell window here option from the context menu that appears when you shift-right-click a folder in Explorer. This allows you to open PowerShell in the current window without having to change the directory. -
Type msiexec /i and do one of the following:
- Type the file name of the BricsCAD® installer (for example BricsCAD-V23.1.01-1-en_US(x64).msi).
- Drag the BricsCAD® installer file from the Windows Explorer dialog to the command window.
Type /qn in the command prompt.
Type /norestart in the command prompt to suppress the restarting after the installation is complete.
(option) Add ADDDESKTOPSHORTCUT="" to suppress the addition of a desktop shortcut.
(option) Add SHOWRELEASENOTES="" to suppress the display of the Release Notes when the installation completes.
(option) Add APPLICATIONFOLDER="your_app_folder" to install BricsCAD® in a custom folder.
(option) Add BRXLICENSEDESTFILE="path_to_lic_file" to specify a folder for the license file if any of the properties BRXLICENSEKEY, BRXLICENSEFILE or BRXLICENSESERVER are defined.
The default folder is APPLICATIONFOLDER\BricsCAD.lic.
(option) Add BRXLICENSEKEY="your_license_key" to activate the license and store it in the folder specified by BRXLICENSEDESTFILE.
(option) Add BRXLICENSEFILE="your_license_file" to copy the license file to the folder specified by BRXLICENSEDESTFILE.
(option) Add BRXLICENSESERVER="host", or BRXLICENSESERVER="port@host" (*) to create a license file in the folder specified by BRXLICENSEDESTFILE, containing the server host specification.
(*) If your license server is using a different port than default port 5053.
- (option) Add REBOOT=ReallySuppress to suppress a restart after the installation is complete.
(option on 32-BIT only) Add INSTALLVBA="0" or INSTALLVBA="" to not install VBA.
Note: The 32-BIT version is only available for BricsCAD V20 and older.The complete entry in the command prompt can be: msiexec /i "BricsCAD-Vxx.x.xx-x-en_US(x64).msi" /qn ADDDESKTOPSHORTCUT="" SHOWRELEASENOTES="".
Press Enter to launch the installation.
- For more options, type: msiexec /? in the command prompt.
- You can find more information about the msiexec command on the Microsoft website.
