Silent installation (Windows only)
For silent installation, you need admin rights.
- Open PowerShell or Command Prompt and change the directory (cd) to the location of the BricsCAD® installer MSI file.Note: On Windows 10 or higher, you can access the Open PowerShell window here option from the context menu that appears when you shift-right-click a folder in Explorer. This allows you to open PowerShell in the current window without having to change the directory.
- Type
msiexec /iand do one of the following:- Type the file name of the BricsCAD® installer (for example, BricsCAD-V25.1.05-1-en_US(x64).msi).
- Drag the BricsCAD® installer file from the Windows Explorer dialog box to the command window.
- Type
/qnin the command prompt. - Type
/norestartin the command prompt to suppress the restarting after the installation is complete. - (Optional) Add
ADDDESKTOPSHORTCUT=""to suppress the addition of a desktop shortcut. - (Optional) Add
SHOWRELEASENOTES=""to suppress the display of the Release Notes when the installation completes. - (Optional) Add
APPLICATIONFOLDER="your_app_folder"to install BricsCAD® in a custom folder. - (Optional) Add
BRXLICENSEDESTFILE="path_to_lic_file"to specify a folder for the license file if any of the properties BRXLICENSEKEY, BRXLICENSEFILE or BRXLICENSESERVER are defined.The default folder is: C:\ProgramData\Bricsys.
- (Optional) Add
BRXLICENSEKEY="your_license_key"to activate the license and store it in the folder specified by BRXLICENSEDESTFILE. - (Optional) Add
BRXLICENSEFILE="your_license_file"to copy the license file to the folder specified by BRXLICENSEDESTFILE. -
(Optional) Add
BRXLICENSESERVER="host", orBRXLICENSESERVER="port@host"(*) to create a license file in the folder specified by BRXLICENSEDESTFILE, containing the server host specification.(*) If your license server is using a different port than default port 5053.
- (Optional) Add
REBOOT=ReallySuppressto suppress a restart after the installation is complete. - (Optional on 32-BIT only) Add
INSTALLVBA="0"orINSTALLVBA=""to not install VBA.Note: The 32-BIT version is only available for BricsCAD V20 and older. - Press Enter to launch the installation.
Note:
- For more options, type:
msiexec /?in the command prompt. - You can find more information about the msiexec command on the Microsoft website.
Examples of command prompts:
- To perform a silent installation while suppressing the creation of a desktop shortcut:
msiexec /i "BricsCAD-Vxx.x.xx-x-en_US(x64).msi" /qn ADDDESKTOPSHORTCUT="" - To perform a silent installation while suppressing the creation of a desktop shortcut and the display of Release Notes:
msiexec /i "BricsCAD-Vxx.x.xx-x-en_US(x64).msi" /qn ADDDESKTOPSHORTCUT="" SHOWRELEASENOTES="" - To execute a silent installation and activate the license using the provided license key:
msiexec /i "BricsCAD-Vxx.x.xx-x-en_US(x64).msi" /qn BRXLICENSEDESTFILE= "C:\ProgramData\Bricsys\BricsCAD.lic" BRXLICENSEKEY="****-****-****-****-****"The license file, BricsCAD.lic, is generated at the specified location, C:\ProgramData\Bricsys, ensuring that all BricsCAD versions automatically find it.
- To copy the existing BricsCAD.lic file to the specified directory, C:\ProgramData\Bricsys, ensuring that all BricsCAD versions automatically find the license file:
msiexec /i "BricsCAD-Vxx.x.xx-x-en_US(x64).msi" /qn BRXLICENSEFILE= "D:\BricsCAD.lic" BRXLICENSEDESTFILE="C:\PROGRAMDATA\bricsys\BricsCAD.lic" - To create the license file containing the server host specification in the assigned folder, C:\ProgramData\Bricsys, ensuring that all BricsCAD versions automatically find it:
msiexec /i "BricsCAD-Vxx.x.xx-x-en_US(x64).msi" /qn BRXLICENSESERVER="port@host" BRXLICENSEDESTFILE="C:\PROGRAMDATA\bricsys\BricsCAD.lic"
