Network license usage report
Possibilities to check the network license usage:
- On the RLM web UI (localhost:5054) check the license server status.
- In the bricsys.dlog file from the RLM installation folder (contains the IN/OUT information).
- Adding the REPORTLOG option to the bricsys.opt as follows:
REPORTLOG +D:\your_path\report_name.logThis option can be found in the Reprise Documentation. Choose your RLM version, then click Next and go to the section.
Note:- Reread/restart the license server after adding the option.
- The
+sign means the new data is appended to the file, otherwise the file is overwritten.
- Using a third party software, for example:
- RLM License Administration Bundle
Browse to https://support.reprisesoftware.com/support/admin/license-administration-bundle/
- JTB FlexReport
Browse to https://jtbworld.com/jtb-flexreport
