TIMEOUT and TIMEOUTALL ISV options
About
The TIMEOUT and TIMEOUTALL options set the inactivity timeout for Network licenses.
If the application does not contact the license server after the specified time of inactivity, the license server performs an automatic check-in of the license.
| Option | Description | Syntax | Example |
| TIMEOUT | Sets the inactivity timeout per product. | TIMEOUT secs [product [id=nnn]] | TIMEOUT 3600 bricscad id=nnn |
| TIMEOUTALL | Sets the inactivity timeout for all licenses present on the server. | TIMEOUTALL secs | TIMEOUTALL 3600 |
Note: The default minimum TIMEOUT or TIMEOUTALL in RLM is 3600 seconds.
How to set the TIMEOUT or TIMEOUTALL options
Steps to set the options:
- Go to one of the following:
- The bricsys.opt file, located in the Bricsys Network License Server installation folder.
- The Reprise License Server Administration. Browse to http://localhost:5054 on the Network License Server. Click Status in the menu on the left side, then click bricsys in the OPTIONS column for the bricsys ISV row.
- Add a line with the syntax for the TIMEOUT or TIMEOUTALL options.
- Perform Reread/Restart the license server.
Note: For more information about license pooling see the License pooling article.
