Using a Network license on a client computer
Once the network license is activated on the license server, it can be used on client computers.
  1. Do one of the following:
    • If you start BricsCAD® for the first time, click the Activate license button in the BricsCAD dialog box.
    • If you replace or upgrade an existing license, launch the LICENSEMANAGER command, click Manage License and click Modify.
  2. Check the Network License option in the License Manager > Activate BricsCAD dialog box.
  3. Type the host name or IP address of the license server in the Server name or address field (1).
  4. (Optional) Type the port number in the Port Number field.
  5. If your computer is connected to the license server through a proxy server, click the Proxy Settings button to configure the proxy settings for a network license.
    Note: Proxy Settings are also configurable from the Settings dialog box.
  6. Click the OK button.
