Drawing properties
The DWGPROPS command opens the Drawing Properties dialog box, showing the general information and user defined properties stored within a drawing.
The Drawing Properties dialog box includes:
- General information: drawing data
- Summary: editable default properties
- Statistics: history data
- Sheetset: info about the associated sheetset
- User defined custom properties
Drawing properties can be referenced in fields.
Opening the Drawing Properties dialog
Do one of the following:
- Choose Drawing Properties... in the File menu.
- Execute the DWGPROPS command.
Defining default properties
- On the Drawing Properties dialog box, click the Summary tab page.
- Fill out the property fields.
- Click the OK button.
Creating custom properties
On the Drawing Properties dialog box, click the Custom tab page.
- Click the Add button.
The Custom Property dialog appears.
- Type a name in the Name field.
The custom property name is listed under Document in the Field dialog.
- Type a value in the Value field.
The value is displayed where the custom property is inserted as a field.
