Making parallel copies
The OFFSET command creates a copy of linear entities and aligns them parallel to the original entities at a specified distance. You can make parallel copies of arcs, circles, ellipses, elliptical arcs, lines, two-dimensional polylines, rays and infinite lines.
Depending on the selected options set by the SELECTIONMODES system variable, the OFFSET command accepts:
- an edge of a 3D solid if the Select Edges option is set.
- the outline of a 3D solid face if the Select Faces option is set.
- enclosed boundaries if the Select Detected Boundaries option is set.
Note: The OFFSETGAPTYPE settings variable controls how potential gaps between segments are treated when closed polylines are offset.
Making a parallel copy at a specified distance
- Launch the OFFSET command.
- Do one of the following:
- Press Enter to accept the current distance.
- Type a new distance in the Command line.
- Define a new distance by specifying two points.
- Select a linear entity.
A preview of the parallel copy is displayed depending on the current cursor position with respect to the selected entity.
- Click a point.
The parallel copy is created.
If the OFFSETERASE system variable is turned on, the original entity is deleted.
- Select another entity.
- Press Enter to stop.
Making a parallel copy through a point
- Press Enter to accept the default Through point option (= when last used).
- Choose the Through point option.
The parallel copy is dynamically displayed.
- Click a point to create the parallel copy.
