Operations and functions in expressions
Operators
Operation Character Description
Addition + Produces the sum of numeric values.
Subtraction - Subtracts the two numeric values.
Multiplication * Multiplies the numeric values.
Division / Divides two numeric values.
Exponentiation ^ Calculates the exponential value of the given numbers.
Remainder operator % Gives the remainder after the division of one numeric value to another.
e.g. 5%2 = 1, because 5/2 leaves remainder of 1.
Expressions
Expressions are evaluated according to the standard mathematical rules of precedence:
  1. Expressions within brackets; innermost sets first.
  2. Standard operations order:
    • 1. exponent
    • 2. multiplication and division
    • 3. addition and subtraction
  3. Operators of equal precedence from left to right.
The following functions can be used in expressions:
Function Syntax
Sine sin(expression)
Cosine cos(expression)
Tangent tan(expression)
Arc sine asin(expression)
Arc cosine acos(expression)
Arc tangent atan(expression)
Hyperbolic sine sinh(expression)
Hyperbolic cosine cosh(expression)
Hyperbolic tangent tanh(expression)
Arc hyperbolic sine asinh(expression)
Arc hyperbolic cosine acosh(expression)
Arc hyperbolic tangent atanh(expression)
Square root sqrt(expression)
Signum function (-1,0,1) sign(expression)
Round to nearest integer round(expression)
Truncate decimal trunc(expression)
Round down floor(expression)
Round up ceil(expression)
Absolute value abs(expression)
Largest element in array max(expression1;expression2)*
Smallest element in array min(expression1;expression2)*
Degrees to radians d2r(expression)
Radians to degrees r2d(expression)
Logarithm, base e ln(expression)
Logarithm, base 10 log(expression)
Exponent, base e exp(expression)
Exponent, base 10 exp10(expression)
Power function pow(expression1;expression2)*
Random decimal between 0 and 1 Random
* Use the list separator character as defined on your system: , (comma) or ; (semicolon).
Note:
  • The constants Pi=3.14... and e=2.72... can be used in expressions. The constants names are not allowed to be used as a parameter or constraint name.
  • The CLEANUNUSEDVARIABLES command purges parameters that are not used in constraint expressions or linked to dimensions.
