AI Predict
The AI Predict ribbon provides suggestions based on your personal BricsCAD® usage, and similar users. The AI Predict tab has two states: an empty state and a populated state.
You can add or remove the AI Predict ribbon tab by removing or adding it to the CUI file.
The AI Predict tab in the empty state:
- Sign Up
- The Sign Up button opens the BricsCAD Analytics Program dialog box.
The AI Predict tab in the populated state:
- Analytics Settings
- The Analytics Settings button opens the BricsCAD Analytics Program dialog box.
- Other Command Suggestions
- Displays commands used by other users with similar interest as yours.
- Personal Command Suggestions
- Displays the most important commands used.
Note: Panels will be populated from the first day of usage BricsCAD® with commands based on your interaction with BricsCAD® via Quad, command line, ribbon, menu, and toolbars. Also, not everyone will be eligible for all models, depending on how we categorize them.
- Next Commands
- Dynamically displays some predicted commands which could be used by the user after the current command.
