Layer utilities
The layer utility commands help you to easily manipulate the On/Off, Thaw/Freeze and Unlocked/Locked layer properties by selecting entities. You can then save the result in a Layer State.
The layer utility commands sit on the Layers toolbar and on the Home / Layers ribbon panel in the Drafting and Modeling workspaces.
Command | Icon | Description |
LAYON | Turns on all layers that have been turned off. | |
LAYOFF | Turns off layers associated with selected entities. | |
LAYFRZ | Freezes layers associated with selected entities. | |
LAYTHW | Thaws all frozen layers. | |
LAYLCK | Locks layers associated with selected entities. | |
LAYULK | Unlocks layers associated with selected entities. | |
LAYISO | Isolates layers associated with selected entities. If no entity on the current layer is selected, the layer of the entity that is selected first temporarily becomes the current layer until the LAYUNISO command is executed. | |
LAYUNISO | Restores layers isolated by the LAYISO command. |
