Folder Access
Give access rights to roles. You can select a folder and set the access rights per role.
Folder access inspector
Viewing rights
Printing rights
Downloading rights
Adding object rights
Adding revision rights
Annotating rights
Editing rights
Deleting rights
Attaching a workflow rights
Adding a subfolder rights
Sharing rights
Attaching a form rights
Access types
No access
Access own: Rights to objects the user created or uploaded himself in the folder
Access all: Rights to all objects in this folder
Selection bar
Easily switch between By role and By folder view.
Toggle access
You can use the top and right handles to quickly toggle the access rights:
no access
access own
access all
Create Snapshot
Take a back-up of your access rights at this moment in time.
Revert Snapshot
Revert to the access rights to a previously saved snapshot.
