Set up a project
This chapter informs you how to get a project up and running.
You can set up a project from the beginning:
- Create a new project
- Edit the project settings
- Create the folder structure
- Define roles
- Update access rights
- Add users and send an invitation mail.
As an alternative, you can create a copy of an existing project and select the options you want to copy to the new project.
Important: Only the project administrator can create a new project, or copy an existing project.
Note: A customer can have multiple project administrators, managed by our support team.
