Edit the project settings
When a project is created, you can edit the project settings:
- Select the project.
- Click Administration
in the toolbar. - Click Project settings in the tool menu.
- Click the DETAILS tab.
- Add, or edit the project details:
- Project picture
- Project name
- Project description
- Location
- Click Save changes.
A pop up window informs you that the project is successfully updated.
- Click the DOCUMENTS tab.
- Select the option button of the document versioning you want to use to track the progress of a document:
- Use standard versions (default)
Select the option you want to use from the drop-down menu.
Example: Version 1
- Use minor and major versions
- Select the option you want to use from the drop-down menu next to Major versioning system.
- Select the option you want to use from the drop-down menu next to Minor versioning system.
Example: Version 1.A
Each major version can represent a milestone the document has reached.
- Enable or disable the Document settings:
- Allow locking of documents.Note:
- A locked document can not be moved or edited.
- A locked document can be unlocked:
- by an administrator
- by the user that locked the document
- by uploading a new revision of the document
- Add signature footer when printing documents:
An extra line is added in the footer of each document that is printed to PDF: Printed by Firstname Lastname (date).
- Allow deleting of revisions.Note: A document needs at least one revision. If you want to delete all revisions, you must delete the document.
- Edit the Document statuses:
The default document statuses are: draft, proposal, in preparation, revised, approved with remarks, approved, final, archived, and obsolete.
- Hover over a status, click
, and drag and drop the status to change the order. - Hover over a status and click
to edit the status. - Hover over a status and click
to delete a status. - Hover over a status and click
to set the status as default status.When you upload a document, this will be the selected status by default.
- Click add status, enter a name and click Add to create a new status.Note: The order of the statuses in this list determines the order of the statuses in the drop-down menu when uploading a new document.
- Edit the Time and date:
Allows you to select the working days.
- Click the ADMINISTRATORS tab.
- Administrators can view all notes, notifications and annotations.
When creating a new private message, project members will be informed that the message can be read by project administrators.
- Administrators can replace the latest document revision.
- If applicable, enable Multi-factor authentication.
To activate multi-factor authentication for a project, go to and turn on the Multi-factor authentication option.
- Enable Lock recycle bin if you do not want items to be removed from the recycle bin.Important: Once the recycle bin is locked, it can only be unlocked by sending a support request to our support team.
