Copy a form
You can copy a form:
- Click Forms
in the toolbar. - Select the applicable form folder
in the tool menu. - Select the applicable form in the content pane.
- Click the ellipsis button
at the top of the content pane.A context menu pops up.
- Click Copy.
The Copy window appears.
- Select the form folder where you want to copy the form to.Tip: You can copy the form to a different project.
- If applicable, enable the Copy data option.
The Copy data option copies all form entries with the form.
- Click Copy.
A pop-up window informs you that the form is successfully copied.
Note: If the form is copied from project X to project Y with the Copy data option enabled, the form entries are retained. For example, if the form includes a Counter field and it is linked to multiple folders, the counter takes into account all existing entries across those folders.
