Delete a form
If you delete a form, the form is moved to the Recycle bin.
You can delete a form:
- Click Forms
in the toolbar. - Select the applicable form folder
in the tool menu. - Select the applicable form in the content pane.
- Click the ellipsis button
at the top of the content pane.A context menu pops up.
- Click Delete.
The Delete form window appears.
- Click Delete to delete the form.
A pop-up window informs you that the form is successfully deleted.
Note:
- You need the appropriate permission to be able to delete a form.
- If the form is permanently deleted (including from the Recycle bin), the metadata attached to documents via form is removed. Similarly, if any form fields are deleted, all metadata associated with these fields is deleted.
