Delete a form entry
You can delete an entry from a form:
- Click Forms
in the toolbar. - Select the applicable form folder
in the tool menu. - Select the applicable form in the content pane.
- Select a form entry.
- Click the ellipsis button
at the top of the content pane.A context menu pops up.
- Click the Delete button.
The Delete form window appears.
- Click Delete.
A pop-up window informs you that the form is successfully deleted.
