Edit a form
You can edit the form:
- Click Forms
in the toolbar. - Select the applicable form folder
in the tool menu. - Select the applicable form in the content pane.
- Click the ellipsis button
at the top of the content pane.A context menu pops up.
- Click Edit.
The Form editor opens.
- Edit the form.Note: See more information about the form fields in the Create a form article.
- Click Save.
A pop-up window informs you that the form is saved.
- Close the Form editor.
