Reservations are blank documents to be filled in by the project member. A reservations is used as placeholder for the final document. The final document can be added as a revision, which will replace the placeholder.
You can add a reservation to a folder with metadata added and Rename uploaded documents based on the fields' content enabled:
Click Files
in the toolbar.
Select the applicable (sub)folder in the tool menu.
Click the ellipsis button
at the top of the content pane.
A context menu pops up.
- Click Add reservation.
The Add reservation window appears.
Edit the number of reservations.
Update the status.
If applicable, enter a description.
Click Add.
A pop up window informs you that the reservation is successfully added.
