-ANIMATIONEDITORPLAYBACK command
Loads animation graphics via Command line.
Loads animation graphics data from a zip-archive or a folder, with the Animation Editor panel closed. Playback options for graphics are available in the Command line prompt until the command is closed.
Note:
  • Adding and modifying camera effects in animation graphics playback mode is not supported for this command.
  • When Animation Editor panel is active, the command has the same functionality as ANIMATIONEDITORPLAYBACK command.
Method
Choose a Zip-file or Folder to load animation graphics to your drawing.
Options within the command
Play
Starts the playback for the animation.
paUse
Pauses the playback.
Stop
Stops the playback.
Render
Opens the Render video dialog box that allows you to set the render options for your animation.
Cancel
Cancels the command.
