ACETUCS-BOTTOM command (Express Tools)
Changes the UCS so that the XY-plane is parallel to the bottom plane of the drawing and the Z-axis points away from it.
Method
The UCS automatically changes when running the command.
ACETUCS-BOTTOM command (Express Tools) - BricsCAD Lite & Pro | Bricsys Help Center
