ADDAREALABELS command
Adds area labels at the centroids of closed polylines, 3D polylines, MPolygons, or strings.
Icon:
Method
Choose an area label style from the available ones displayed in the Command line and then select the entities (closed polylines, 3D polylines, MPolygons, or strings).
Note:
- When the label is pinned inside the entity, it has one grip. When the label is dragged outside the entity, it has two grips.
- You can change the area label properties from the Properites panel, such as Name, Description, Area label style, Entity, Dragged, Pinned, and Label rotation.
