AI_BOX command
Creates a 3D polyface mesh in the shape of a box.
Icon:
Creates a 3D polyface mesh in the shape of a rectangular or square box. Choose from a combination of options including corner, length, width, height, cube, and rotation angle.
Method
There is one method to begin creating a box:
- Corner of box
Options within the command
- Length of side of box
- Specifies the length of the box.
- Set width of box
- Specifies the width of the box.
- Cube
- Specifies a single distance to use for the length, width, and height of the box.
- Length
- Width
- Height
- Height of box
- Specifies the height of the box.
- Rotation angle for box
- Specifies the rotation angle of the base of the box in the xy-plane. The default value is 0.
- Corner of box
- Height
- Width
- Length
- Rotation angle
