AI_DISH command
Creates a 3D polygon mesh in the shape of the bottom half of a sphere.
Icon:
Creates a 3D polygon mesh in the shape of the bottom half of a sphere. Choose from a combination of options including center, radius, diameter and number of segments.
- Center
- Diameter
- Radius
- Top to bottom segments
- Segments around dish
Method
There is one method to begin creating a dish:
- Center of dish
Options within the command
- Center of dish
- Specifies the center of the dish’s open end.
- Set radius of dish
- Specifies the radius of the dish.
- Diameter
- Specifies the diameter of the dish.
- Number of segments around dish
- Specifies the number of isolines, perpendicular to the xy-plane, used to simulate the dish’s curved surface. The default value is 16.
- Number of top-to-bottom segments
- Specifies the number of isolines, parallel to the xy-plane, used to simulate the dish’s curved surface. The default value is 8.
