AI_SPHERE command
Creates a 3D polygon mesh in the shape of a sphere.
Icon:
Creates a 3D polygon mesh in the shape of a sphere. Choose from a combination of options including center, radius, diameter, and number of segments.
- Center
- Diameter
- Radius
- Latitudinal segments
- Longitudinal segments
Method
There is one method to begin creating a sphere:
- Center of sphere
Options within the command
- Center of sphere
- Specifies the center of the sphere.
- Set radius of sphere
- Specifies the radius of the sphere.
- Diameter
- Specifies the diameter of the sphere.
- Number of longitudinal segments
- Specifies the number of isolines, perpendicular to the xy-plane, used to simulate the sphere’s curved surface. The default value is 16.
- Number of latitudinal segments
- Specifies the number of isolines, parallel to the xy-plane, used to simulate the sphere’s curved surface. The default value is 16.
