AMCLEAN command
Saves a mechanical 2D drawing as a non-mechanical drawing.
Note: This command only works for drawings that contain mechanical entities. To set the environment for BricsCAD Mechanical drawings, see the Overview of 2D Mechanical Drawings commands article.
Opens the Save file as non-mechanical dialog box to save a mechanical 2D drawing as a non-mechanical drawing in DXF or DWG format.
Method
This command is available when the drawing contains mechanical 2D entities and the LOADMECHANICAL2D system variable is On.
