AMCLEAN command
Saves a mechanical 2D drawing as a non-mechanical drawing.
Cleans the drawing from Mechanical 2D data to be able to be exported to a DXF file.Method
This command is available when the drawing contains mechanical 2D entities and the LOADMECHANICAL2D system variable is ON. The command saves the drawing that contains mechanical 2D entities to a non-mechanical drawing so that it can be exported to DXF file format.
Note: This command only works for drawings that contain mechanical entities. To set the environment for BricsCAD Mechanical drawings, see the Overview of 2D Mechanical Drawings commands article.
Opens the Save file as non-mechanical dialog box to choose a file name for the non-mechanical drawing.
