AMPARTREFEDIT command
Edits Part Reference properties.
Note: This command only works for drawings that contain mechanical entities. To set the environment for BricsCAD Mechanical drawings, see the Overview of 2D Mechanical Drawings commands article.
Method
Note: The Part Reference symbols is added to the AM_12 layer.
Select the Part Reference symbol, and then the Part reference dialog box displays.
Note: The Part References symbols from the entire drawing are highlighted.
