AMPOWERDIM_VER command
Creates vertical linear dimensions.
Icon:
The command is a shortcut to the Linear Vertical option of the PDIM command.
Method
Define the two extension lines or select the entity and specify the location of the dimension. The Edit Dimensioning dialog box opens to define the parameters of the dimension.
For more information about the dialog box, see the related article Edit Dimensioning dialog box.
Note:
- When SNAP is ON, the dimension line freezes during placement to the snap distance and is marked with red color.
- Press Enter to be able to select an entity.
- Press Esc to finish the command.
Options within the command
- Placement options
- Specifies the object to include for distance snap calculation.
- Options
- Opens the Placement Options dialog box to set the snap value.
