AMPOWEREDIT command
Identifies the selected dimension or mechanical symbol entity and executes the most relevant command to edit it.
Note: This command only works for drawings that contain mechanical entities. To set the environment for BricsCAD Mechanical drawings, see the Overview of 2D Mechanical Drawings commands article.
The AMPOWEREDIT command identifies any dimension or mechanical symbol entity you select and executes the most appropriate command to edit it. For example, if you run the command and select a dimension entity, the Edit Dimensioning dialog box opens.
Note: The AMPOWEREDIT command is also launched when you double-click one of the dimension or mechanical symbol entities.
