AMRESCALE command
Rescales dimensions, symbols, tables and texts in both model space and layout.
Method
This command is available when a mechanical 2D drawing is opened.
- There are two use cases to activate the mechanical entities:
- When creating a new drawing that contains mechanical entities:
- Set the LOADMECHANICAL2D system variable to ON (1).
- Start a new drawing using a Mechanical2d template.
- When opening a drawing that contains mechanical entities:
- Open an existent ACM drawing and start special symbols creation.
Enter the new symbol scale and select the entities you want to rescale. Entities rescaled in both model space and layout are dimensions, symbols, and tables. Annotations are enlarged or shrunk without affecting the drawing geometry.
