AMSETUPDWG command
Changes the current standard of a mechanical 2D drawing or set up a mechanical 2D template for a non-mechanical drawing.
Icon:
Note: This command only works for drawings that contain mechanical entities. To set the environment for BricsCAD Mechanical drawings, see the Overview of 2D Mechanical Drawings commands article.
Method
After opening a drawing which contains mechanical entities there are two use cases:
- The standard of the current mechanical drawing can be changed by selecting another DWT mechanical2D template file from the Choose one of the Mechanical 2D template file dialog box.
- The standard of a non-mechanical drawing can be changed with a standard of a mechanical drawing, by selecting a DWT Mechanical2D template file from the Choose one of the Mechanical 2D template file dialog box. The mechanical-related data, like dictionaries, style tables, etc. will be initialized.
Note:
- A message with the name of a new standard will be displayed on the Command line.
- If select a template without a defined mechanical standard, an error message is displayed in the Command line: You did not choose a mechanical 2D template.
- If the mcad2d functionality is not available, an error message will be displayed in the Command line.
