AMTAPERSYM command
Creates a slope symbol in the drawing space.
Icon:
Note: This command only works for drawings that contain mechanical entities. To set the environment for BricsCAD® Mechanical drawings, see the Overview of 2D Mechanical Drawings commands article.
Method
Note: The slope symbol is added to the AM_5 layer.
Select a taper centerline or a slope baseline, then select a taper or slope object to attach and specify the start and next points for the slope symbol location. The gradient is automatically calculated.
The Properties panel contains information about the drawing standard and the properties of the slope symbol.
