ANIMATIONEDITORRECORD command
Records animation graphics.
Records animation graphics and saves it to a zip-archive or to a folder of your choice. After selecting the needed save option, the recording process will start. Depending on the complexity of the model, this can take a long time.
Options within the command
- Zip-file
- Opens the Select a zip-file name to save animation graphics dialog box that allows you to save the animation graphics to a zip-archive.
- Folder
- Opens the Select a folder to save animation graphics dialog box that allows you to save the animation graphics to a folder of your choice.
