APPAUTOLOADER command
Lists or reloads all loaded plugin bundles.
Manages the plugin application bundle service by either listing or reloading the loaded bundles.
Plugin bundles can be loaded from the following file paths:
Bundles Windows Linux macOS
User %APPDATA%/Bricsys/ApplicationPlugins/ ~/Bricsys/ApplicationPlugins/ ~/Library/Application Support/Bricsys/ApplicationPlugins/
Machine %PROGRAMFILES%/Bricsys/ApplicationPlugins/ /opt/Bricsys/ApplicationPlugins/ /Library/Application Support/Bricsys/ApplicationPlugins/
Note: The %APPDATA%/Bricsys/ApplicationPlugins/ folder is not created automatically on installation. It may be created manually as needed, either by the user or an app installer.
Options within the command
List
Lists all currently loaded plugin bundles in the Command history.
Reload
Reloads all current plugin bundles from the ApplicationPlugin folders. This option ignores the value of the APPAUTOLOAD system variable.
