APPAUTOLOADER command
Lists or reloads all loaded plugin bundles.
Manages the plugin application bundle service by either listing or reloading the loaded bundles.
Plugin bundles can be loaded from the following file paths:
- Default path: C:\Program Files\Roaming\Bricsys\ApplicationPlugins
- Alternative path: C:\Users\%username%\AppData\Roaming\Bricsys\ApplicationPluginsNote: This path is created manually or by the plugin bundle installer, if necessary.
Options within the command
- List
- Lists all currently loaded plugin bundles in the Command history.
- Reload
- Reloads all current plugin bundles from the ApplicationPlugin folders. This option ignores the value of the APPAUTOLOAD system variable.
