AREA command
Finds the area and perimeter of 2D entities.
Icon:
Alias: AA
Method
Specify the points that define the area for which BricsCAD will report the area and perimeter.
Options
- find area of one Entity
- Provides the area and/or perimeter of the selected entity.
- Add areas together
- Allows to add up the areas of two or more entities.
- Subtract areas
- Allows to remove areas of entities from the total area and perimeter.
Note: This option can only be used after you have found the area
of at least one entity.
