ATTDISP command
Sets the display mode of attribute text in the drawing.
Icon:
Alias: AD
Toggles the display of attribute text in the drawing, between turn all on, turn all off, or turn on only non-visible ones.
When attributes are off or invisible, they are not displayed in the drawing and are not plotted.
Options within the command
- Attribute display mode
Changes the display of attribute values:
- display attribute (ON): displays all attributes, including those set to invisible mode by the ATTDEF command.
- hide attributes (OF): hides all attributes.
- display Normally: displays attributes, except those set to invisible mode.
