AUTOCOMPLETE command
Specifies how the auto-complete function works in the BricsCAD Command line.
This command sets the behavior of the auto-complete function in the BricsCAD Command line. This is done by defining how to append and list which commands and system variables are displayed.
Note: There are six settings, which can also be set by right-clicking in the Command line, using the AutoComplete item in the context menu.
Options within the command
- Append
- Toggles the automatically append suggestion as you type.
- List
- Toggles the display of the suggestions list.
- System Variables
- Toggles whether the system variables are included in the list of suggestions or not.
- Delay
- Specifies the delay time before the list of suggestions displays.
- ON
- Switches on auto-complete mode.
- OFf
- Switches off auto-complete mode.
AI-based AutoComplete suggestions
This functionality is an extension to the list of auto-completed commands. This feature adds three more suggestions on top of the ones that are completed in an alphabetical order. These three suggestions are predicted by a Machine Learning model, which is trained based on the commands the user has used in the past.
This feature is available only for the users that choose to be a part of the Diagnostics & Usage Data Program.
Note: This feature is set OFF by default. It can be enabled from the Settings dialog box.
