BIMAPPLYPROFILE command
Applies a profile to linear entities and linear solids.
Icon:
Allows you to add profiles, to detach current profile and to convert solids to line.
Note:
- Make sure the selected paths are placed in the XY plane of the current UCS.
- The linear entities accepted as paths are: lines, polylines, arcs, circles, elliptical arcs, ellipses, and helixes.
- Open and closed splines are accepted as paths only if they have default tangents that are not self-intersecting.
Methods
There are two methods to apply profiles:
- Choose a profile from the library.
- Choose a profile entity in the drawing.
Options within the command
- Select path
- Select linear entities or linear solids.
- Select profile
- Select a profile entity in the drawing (a closed 2D entity, a region or an existing linear solid) or press Enter to display the Profiles dialog box.
- Apply profile?
- Quarter turn: rotates the profile 90° counterclockwise.
- Rotate: rotates the profile at a user-defined angle. Positive values rotate the profile counterclockwise.
- Delete clippings: removes all clippings from the selected linear solid(s).
- LIbrary
- Opens the Profiles dialog box to change the profile.
- convert solids to Line
- Converts linear solids to their axis line.
- DEtach current profile(s)
- Detaches profiles only if the entities have an attached profile.
