BIMBUILDINGSYSTEM command
Creates or edits a BIM building system group.
Method
Enter an existing Building System group name or a name for a new Building System group, then select the entities to add to or remove from the Building System group.
Note: Building Systems created with BIMBUILDINGSYSTEM command are exported with IFCEXPORT command as IfcBuildingSystem.
Options within the command
- List building systems
- Lists all existing BIM Building System groups in the Command line.
- Create a building system
- Creates a new BIM Building System group.
- Show properties
- Allows you to edit the properties. The available properties are displayed in the Command line.
- Ifc properties
- Allows you to edit the IFC Properties. The available IFC properties are displayed in the Command line.
- Delete a building system
- Deletes the selected BIM Building System group.
